E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
cx2 Batteries question
Old 02-10-2008 | 03:28 PM
Default cx2 Batteries question
So my flight time is really short, 2-4 min on a battery(eflights). once my battery hits 7.76 volts I have no more lift. it takes about 2-3 min to hit that point. any ideas, it happens to all my eflight batteries. I have the same issue with my DN packs but they now act like eflite batteries. Any ideas, I also have tried to rebalance them by draining the cell that has more voltage to match the other battery.
Old 02-10-2008 | 05:24 PM
Default RE: cx2 Batteries question
Do you have aluminum parts? That will shorten the times. Do you have the stock motors? And how many times have you flown it. When the brushes get to short the flight times will go down. I like the Xtreme motors because you can see when the brushes are getting low and you can't with the stock motors.
Old 02-10-2008 | 08:30 PM
Full AL Upper Lower Swash, Xtreme motors, Boomtownhobbies boom kit. 6 eflite batteries and 4 DN 850mah 15c. about 100+ flights since stock, 40 or so since the xtreme motors. I am replacing the brushes on the 180's as I type, soldering iron is warming up. I just flew 6 packs at the gym and I started have more yaw issues, it got progressively worse as i flew. and then the heli was really loosing power i could not correct any yaw at all it just kept spinning.
Old 02-10-2008 | 08:33 PM
WOW my brushes are crap... i am checking the rest now
Old 02-10-2008 | 08:35 PM
How come the new brushes have a groove horizontal not vertical like it would if it was on the shaft???
Old 02-10-2008 | 10:28 PM
It was my brushes... One had a large chip in it the rest were worn a lot, almost none left on the trailing edges.
Old 02-10-2008 | 11:05 PM
I got to the point where the metal part around the brushes was riding on the inside of the motor and almost no brushes left. 10 second flights gave that problem away.
