CX2 spins uncontrolably
Hey Guys,
I need your help in solving a problem..... when doing peroits (?) it spins faster than I've ever seen it spin, in both directions.
I have no input control on the 3in1 controler... so I'm thinking maybe I lost the gyro. Is that possible to loose just part of the function of a 3in1. Also I have to fly it the entire time, no hands off for me.
Thanks for any help guys,
Chris
Chris
NE
Make sure your swashplate is level that will help with the hands off thing. How low is your gyro? Try turning it up all the way then turn it down slowly until the tail doesn't wag back and forth after a fast spin.
Here is soloboss`s guide to hands off hovering
Once you have been through this and dialed her in hands off is indeed possible
As for spins being fast i would say 3 in 1 fault, did you change / swap / fix anything before this happened ?
