E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
B400 motor unplug
Old 02-22-2008 | 03:00 PM
Default B400 motor unplug
anyone else here try to unplug motor from esc on 400?....It is presenting quite a challenge...afraid to use needle nose...dont wanna damage ends...just curious if anyone has accomplished this bear of a problem!!!!
Old 02-22-2008 | 03:49 PM
Default RE: B400 motor unplug
I took an old pair of needle nose pliers and wrapped several turns of electrical tape around the jaws. I use these to hold the motor leads when connecting or disconnecting them. The tape keeps them from damaging the insulation. It's also easier to see what you are doing if you remove the battery strap when working with the leads.
Old 02-22-2008 | 05:10 PM
sounds like a plan....thanks
Old 02-22-2008 | 08:58 PM
Better still, just use a receiver battery to power your servos when you're doing maintenance / setup. Just unplug the ESC at the receiver and plug in a 4.8v receiver battery. Make sure you don't plug the receiver battery in while the ESC is connected to the receiver.
This has the benefit of avoiding any possibility of inadverent spin-up of the rotors as well as keeping you from having to plug and unplug those important motor connectors.
Old 02-22-2008 | 11:56 PM
seems I read somewhwere in this forum...someone tried that....smoked esc....wouldnt all electrnics respond differntly...as in badly....how bout if I just anchor heli...remove blades....pardon me,just thinkin outside box.....I do appreciate your help...Thanks
Old 02-23-2008 | 04:23 AM
My Feedback: (21)
ORIGINAL: tracks
What are you doing?Not sure if you know but theres a t-hold on the radio.I turn it on whenever im checking servos and what.
Old 02-23-2008 | 05:35 AM
ORIGINAL: tracks
Yep, that was me. Hence the caution to unplug the ESC and plug the receiver battery into that connection on the receiver. As another poster here said, you could just use throttle hold but if you forget or accidently hit that switch you could be in real trouble. Trust me, using a reciever battery is easy and safe. It also has the advantage of not running down your flight battery. Once you do get everything setup, you can have a fully charged battery to go fly with!
Old 02-23-2008 | 01:52 PM
thats just it ..if ya forget the throttle hold...I just anchor heli on tri-pod...remove blades,and go from there....dont wanna smoke my new heli....Thanks for the input
Old 02-26-2008 | 05:42 AM
ORIGINAL: bluercpilot
Even better still, run a short (3" or so) servo extension from the throttle plug on the Rx to the outside and tie it off to the frame. Now it's easy to unplug the motor/ESC and plug in a 4.8V battery for all your adjustments without worrying out getting slapped in the face by the blades or unplugging the motor.
Old 02-26-2008 | 07:29 AM
thanks for that info trader.....gonna try it...
Old 02-26-2008 | 11:39 AM
BryFlyGuy67's Avatar
External battery for setup and testing is the way to go! I never unplug my motors anymore and that's a good thing. The more you disconnect / re-connect those motor leads, the looser they get and this 'could' lead to a high resistance connection, which would be bad.
Old 02-28-2008 | 04:07 PM
Coyote64's Avatar
I just pulled them out with my fingers, and all is well........
