E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Pitch Adjustment
Old 03-09-2008 | 05:36 PM
Default Pitch Adjustment
Hello all
I Have a great problem for u .....
I have just finished rebuilding the rotor head and now i cant get the correct pitch at H or L throttle ...
The swash has been levelled in with the trueblood leveller so no problems there then everything else measure with vernier callipers ....
i can get 0 at mid throttle but the other pitches are off
Old 03-09-2008 | 07:03 PM
zaw
Default RE: Pitch Adjustment
Which heli you got I just completely rebuilt my Blade CP/CP2 mix with BL and readjusted all the pitch and swash etc.
Are you using a after market TX as well..
I'm new to this hobby as well so my information might not be right.
What I do is set the Idle on. Motor and tail disconnected.
Move the throttle stick to Middle. Throttle trim up to 0 as well.
Then set the pitch to 0.
then check the pitch at Full should be around 12+
then checkt he down should be around 10-
If you're using stock radio, 2 or 3 threads after you set the pitch to 0, should give you like 6+ or so at mid stick.
Old 03-09-2008 | 11:19 PM
Are you saying that the pitch at the top and bottom are different? If so all you have to do is raise or lower the swashplate. You will also have to readjust the pitch at mid stick in throttle up because it will change.
Old 03-10-2008 | 02:06 PM
guys its a blade 400 with dx6i i wanted to restore the factory setting which are.... -3 at L....0 at M....11 at H.... stick not doing any 3d at the mo so not to worried about stunt settings
Old 03-10-2008 | 02:27 PM
With a pitch gauge and the motor unplugged start going below center stick until the pitch gauge says -3 degrees. Then you should be able to see what the number is for that setting. Then just put that number into the pitch curve for the first setting.
Old 03-10-2008 | 08:53 PM
zaw
I'm not finish making my friend 400 fly again but if you get the pitch right, at 0 pitch everything on the very complex linkage system should look square.
