cx2 battery
MN
is this possible, a 2000 mah battery for less than the stock![X(][X(] http://www.raidentech.com/3emo710c22hi.html oh and heres the other batterys http://www.raidentech.com/74v.html
You will be able to fly longer with that, but I would prefer to have both high capacity and high C ratings. At 10C, that pack is going to give you about as much "umph" as a stock pack, which isn't much. I have better results when using 15C+ packs. Let us know how you like your packs, though!
MN
lol im not going to get them if you guys dont think they are good. im not really aiming for speed and torque w.e im aiming for fly time. ill look at 15c ones now to see if they have some. i guess it would be cool to have my cx2 lift something up..
ORIGINAL: littleman10101
Nice Battreries but they won't fit into a stock battery tray they are about 1/4 more the size of stock. You could make them fit if you modified your heli, but I would recommend somthing with more "C" rating if you want to fly with such a big heavy battery like that.
ORIGINAL: eat2muchrice
they are longer 86x33x20mm
stock is 68xx25x12mm
still can't fit them into your battery tray without cutting something off.
First of all, the way I modified my battery tray is to clip off the parts that hold the battery in place, keeping the battery tray frame, to which the skids attach. As I said, I use velcro and velcro straps to keep my packs in place. Not only does that allow me to use different sizes of batteries, but it also gives me more control over the placement of teh pack, which helps me balance the COG.
Second, running a 3S, 11.1V pack on a CX2 should done at your own risk! There is a chance of frying your electronics / motors if you do this.
MN
well my batt is fine like it is... i dont know how to explain how its in there...i wont be using a 3 cell one =p if anything ill be using the dn power tones with 950 mah 15c
