E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
CX2 4-in-1 HELP!
Old 05-08-2008 | 11:38 PM
Crusader23's Avatar
Default CX2 4-in-1 HELP!
Hi all,
I just recently added a light to my CX2 and it works using the AUX 5 (4-in-1) and the Gyro switch (DX6i); however, I would like to add another light that I can turn on and off using the TX. The problem is that the AUX 6 is coupled with my throttle position, so the light will only come on either > half stick or < half stick (depending if the controls are normal or reverse). Is there I way I can control this AUX 6 with a toggle switch, so that I can turn a light on and off whenever I like and not when the throttle is in a certain position?
Thanks in advance,
Kenn
