Blade Cx2 Problem
My Blade Cx2 Is always Rotating Counter Clockwise to much i have the trim all the way to the right but it slowly makes its way. I was wonder what I could do to try and fix this or Re-alignment of some sort... I checked for binding and everything spins perfectly smooth...
AB, CANADA
Ya, this is a common problem. I fixed my problem by adjusting the trim pot on the 4-in-1. I gave it a small turn to the right and the problem went away. Give that a shot and let me know how it goes. PM me if you have any more questions.
Steve
Steve
NE
I don't know if you have a 4in1 or 3in1, but on my spare 4in1 there is a white potentiometer that says proportional under it. The 4in1 has the servo wires and motor leads going into it and the battery plugs into it.
Nick
Nick
I had this problem and all i did to fix it was adjust the proportional screw fraction by fraction and now mine flies great. If you want more info PM me and ill give pics as well.[sm=teeth_smile.gif]
Happy Flying,
Lemon
Happy Flying,
Lemon
I actually Turned down the "Gain" and it worked perfect I tried turning up the proportinial but it made it was so i turned down the gain and it worked perftect.. Or maybe I turned it up oh well I don't remember but it Works so I am happy.
