E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Blade CX2 Hovering...
Old 09-02-2008 | 03:24 AM
Wild YFZ 450's Avatar
Default Blade CX2 Hovering...
I Had just realised that when I am flying my Blade CX2 If i throttle up and try to spin Clockwise it was spin Counterclockwise.. If i push the joystick left the Heli will Spin towards the right...And Vice-Versa.. How do I change this back to normal.. Its kind of like if the heli is facing you (Nose) It is normal when it should be reversed.. I just don't get it..
Any help would be appreciated.. ( And there is no Tabs or anything on the Stock radio to reverse it only the Numbers wondering if that was it) Thanks in Advance and Sorry about the back to abck threads
Old 09-02-2008 | 07:58 AM
Default RE: Blade CX2 Hovering...
hey wild
how are your dip switches setup? #1 #6 and #7 should be in the up position, all others should be down.
Cory
Old 09-02-2008 | 09:43 AM
Yeah they are like that.. This is why I am wondering why it is doing this...
Old 09-02-2008 | 09:50 AM
i was wondering if your motor wires were reversed but then the blades would have to be reversed also. or else you wouldn't get lift......hmmmmm...weird. It just started doing that?
Old 09-02-2008 | 10:30 AM
I was flying it around and pointed out how to fly to my friend and then relised it was like that.. It might have been for a few days because I am actually almost used to flying like that..not really thought.
Old 09-02-2008 | 11:19 AM
would you have a picture of the blade setup along with the motor wires?
Old 09-02-2008 | 01:07 PM
Why would you need a Picture of either... The Blades would not fit if put on incorectly.. Also If the motor Wires where Reversed it would not hover at all.... Maybe it is something on the ESC the 3 in 1 may have something on it to switch.. I am not sure....
Old 09-02-2008 | 03:30 PM
madmax22's Avatar
it sounds like something is going backwards?[sm=71_71.gif]
Old 09-06-2008 | 08:28 AM
Wild YFZ 450, I had the same thing happen. The dip switches went goofy on my transmitter. I ended up buying a dx7 and binding it to that. Not a cheap fix. I also bought a T-rex to kind of justify it.
Old 09-06-2008 | 12:53 PM
toxic 2U's Avatar
Why not just flip the dip switchs 1, 6, and 7 to the down position and see if that gets it.
It's worth a shot right ?
