Blade 400 Optional Battery
FL
Hello All:
I just ordered 11.1v 2200 mAh 30C batteries for the Blade 400. I guess I should have asked this question before I ordered but here goes. The Blade manual states batteries should be between 1800 and 2200 mAh but said nothing about the "C" rating. Is it ok to run the blade 400 with 30C batteries? The ESC is rated at 25C will this cause a problem? Thanks
IN
RE: Blade 400 Optional Battery
Busha,
You'll be okay using the 30C battery.. It's over kill, but will give you lot's of horsepower. The "C" rating is determined by how many mAh are required by the motor and servos combined, and only draws the needed mAh to run.. It may only take 15C or less to make everything work properly. Never had a Blade 400, but the logic is the same for all helicopters.
Dave
Dave
ORIGINAL: Busha
Hello All:
Hello All:
NE
ORIGINAL: Busha
Hello All:
Hello All:
Nick
