E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Help
Old 11-11-2008 | 09:02 PM
Default Help
SO I got my lower rotor head, skids, boomtail and blades... Put all together and went to power up but something is not right..
Both upper and lower blades are spinning the same direction. Not sure what I did wrong.. I did take the electronic off so could something be pluged in wrong? A screw to tight on the rotor heads... Help please...
Old 11-11-2008 | 09:19 PM
Default RE: Help
Note which rotor is going backwards. Look at the bottom of the helicopter and determine which motor is hooked to that rotor. Follow your motor leads back to the control box ( 3 in 1 / 4 in 1 ) and turn the connector over. Note that both connectors are pointed the same way when they are both plugged in correctly.
That ought to fix your problem.
If you get both rotors going the correct direction but the tail (rudder) works backwards, pull both motor plugs and switch them.
Soloboss
Old 11-11-2008 | 09:33 PM
Default RE: Help
Hey Solo thanks for that.. Now I have them working right but as soon as I power up to hover the heli spins right fast and out of control. But when I adjust trim to counter it it spins left fast and out of control.. What gives...
Old 11-11-2008 | 10:05 PM
Default RE: Help
Hey I read your post again and figured it out...lol
It flew great.. Man I can't believe I let it sit for months..
Thanks again..
