E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
blade cx wobble
Old 11-28-2008 | 07:39 PM
Default blade cx wobble
cant figure out why my blade cx goes into uncontrolable wobble as soon as it leaves the ground?I replaced almost every part on it.
Old 11-28-2008 | 07:47 PM
Default RE: blade cx wobble
Airrace,
Can you explain in more detail: WOBBLE??
When did this problem start, before or after a crash?
How old is the CX or CX2?
Have you made any modifications with other than Eflite parts?
Do you have a video you could post so we cound see the problem?
We are here to help, we need more info.......................JPEE In California
Old 11-28-2008 | 09:03 PM
its like a top ready to fall over,its a tight rotation till it fall over, its like its top heavy.not sure when it began.
Old 11-28-2008 | 09:10 PM
ORIGINAL: airrrace
http://www.heli-wiki.com/mediawiki/i...et_it_straight
Hope this helps...............JPEE
Old 11-28-2008 | 09:51 PM
Airrace,
I'm gonna guess that you've had a previous crash.. It sounds like the swashplate has seperated. It's a two piece component. It can be corrected. Check it out closely, just use some needle nose pliers to press the two parts back together. The seperation doesn't have to be a lot to cause this problem. Also, make sure that your flybar is straight. This is sometime refered to "Toilet Bowel Effect".
Dave
