CX2 Slides Left
Just got a CX2. Had to replace a skid and rotor blade after a crash. Now I can't get it to hover. It slides left very badly, no matter what I do. Any thoughts?
IL
i had the same problem. check and see if your swashplate has come in two peices. thats probably the problem. i would replace the swash plate and lower rotor heads with the aluminum upgrades.
CA
Adding weight to the rotor head will seriously reduce flight times, those tiny China made motors react badly even by adding a slight amount of weight! Remember these are micro/mini helicopters and are more sensitive to adding any kind of extra weight! As for your current problem take a good hard look at you control rods, arms and swashplate to see if there is unseen damage. If not any of those you might have damaged your 3-in-1 gyro/mixer/esc unit, if everything look ok its time to call e-Flite customer support.
