Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Learning in idle up mode >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-24-2009 | 07:16 PM
bcovish's Avatar
My Feedback: (8)
Default Learning in idle up mode
I'm really a rookie when it comes to helis. I have a B400 and someone told me today that I should learn to fly it in the idle up mode. Never heard this before. What are the pros and cons of learning this way. I must admitt that I am a little intimidated by the speed of the blades and the thought of them going faster kinda scares me while trying to hover.
Old 01-24-2009 | 08:08 PM
Default RE: Learning in idle up mode
Idle up mode on the B400 is what eflite calls stunt mode in the manual. Now a lot of people learning are not ready for stunt mode untill after much practice. I have slowly been learning on my B400 and have been in stunt mode several times. Best not to flip that switch when flying in a confined area because your head speed with immediatly accelerate and the heli may rocket skywards, watch out for low ceilings. An increased head speed is common for idle up flying and makes the helicopter much more responsive. On the B400 stunt mode you will also have much more negative pitch available for doing inverted flying and 3d manuvers. I believe the increased head speed and a more responsive helicopter is what they were trying to direct you towards. What I have done for flying indoors this winter is to drastically reduce my throttle curve for stunt mode. Out of the box your mid point throttle is at 90% with 100% on each end of the curve. I have decreased mine to 75% mid point and 80% on the ends points keeping a nice bell shaped curve. So I can start to fly my helicopter and she will lift of around half throttle then I flip the stunt switch and head speed increases which gives better control response for flying around the gym. Please remember when in stunt mode and you pull back on the throttle the blades keep spinning at the high speed and your pitch response is also increased so the heli will hit the deck fast. Just practice being quick on the stunt mode switch and maybe just use it for short durations to get started. You might even want to board the helicopter to the ground and see how all this works before doing it in the air. Well anyways I hope this helps and good luck learning with your B400!
Old 01-24-2009 | 08:17 PM
Heck no!! Don't use Idle up to learn. If you panic and chop the throttle it will still be full speed but with negative pitch so it will head to the ground twice as fast as gravity can pull it. Then when it does crash the motor will keep spinning until you hit the throttle hold switch on the top right. Learn in normal mode, the heli is less twitchy, easier to control, will not plow into the ground as fast and the motor shuts off when you kill the throttle. This is how I learned and after about 2 months of flying then I started to use throttle up. When you flip that switch the heli runs in 90-100% power all the time so you head speed will be crazy!
Old 01-24-2009 | 08:27 PM
bcovish's Avatar
My Feedback: (8)
Thanks very much guys. I really appreciate the replies. I'll be in the normal mode for a while. And I thought flying jets (turbines) was a challenge at first, it was nothing compared to this.[:@]
Old 01-24-2009 | 09:23 PM
I agree with Xyster. Get comfy with normal mode before doing the stunt mode. What I did is to use 80 70 70 70 80 for throttle curve in Idle 1 to get used to flying like that. Am gradually going to increase it up to 90's / 100. Still learning. It is a little freaky at first because the rotors do not stop turning . Got me a little anxious a few times , before flipping the switch back to normal mode.
