what DD system
Hey youngpilot,
Here is the GWS setup, which is inexpensive, and works quite well... I takes a little bit of modification, but it's pretty simple to install, really...
http://www.eboyztoyz.net/index.php?op=showitem&sku=8605
Or, you could piece the parts together from Eflite, to do the tail like on the new CP Pro 2....but I think that those parts are currently on backorder...so I have heard...[
I have used the GWS setup, pretty nice, and it's a HUGE improvement over the stock tail motor, in both performance, and durability!
Good luck with whatever you chose, either will be a major improvement !!
Glenn
]I have used the GWS setup, pretty nice, and it's a HUGE improvement over the stock tail motor, in both performance, and durability!
Glenn
youngpilot
The E-Flite number for the kit is EFLH 1320 its around 14.00 but like Glenn said its backordered. I have had one on order since June for my CPP.
