DX6I setup help for cpp2
IL
i am new to the hobbie. Just got a cpp2 and a dx6i i was wonder if any one had the setting for a newbee to help with hovering. or just in general i cant get the mixes right the swash plate doesnt move like it does with the stock tx. also i wrecked it to day and broke the tailmotor mount is that ca glue able or do i have to replace it and what is the easy way
Dankhead25
Look at this post that I listed the setting I came up with. Glenn aka rotarydoc gave me some other numbers to try that made it alot better. So read the thread. hope this helps
http://www.rcuniverse.com/forum/fb.asp?m=8512518
NE
You should watch [link=http://www.helifreak.com/showthread.php?t=41692]Finless's videos on CPPM setup.[/link] It will take you through getting the servos moving in the right direction and explain what the settings in the transmitter do. It is on a DX7 and T-Rex 450, but don't worry that it is a different transmitter and heli because the basics work on any heli.
Nick
Nick
IL
thanks for the info i will check out both of them and let you know how i did also is there any mod i should think about doing right off the bat
