Blade CP HELP!!!!
OH
I have an older Blade CP that I can not get flying. I have a 3-n-1 mixer, 6100e bound to a DX7. The servos work fine, but the motors will not! The LED on the 3-n-1 flash red/green the entire time. Any suggestions on what is going on with this *&^@ thing?
NE
In the manual it says if that happens there isn't a connection between the receiver and the 3in1. Where did you plug the throttle and rudder connectors from the 3in1 to the receiver?
Nick
Nick
IL
I do not have any subtrim on throttle. My throttle hold is set to -10.
I would try to arm with no throttle trim and then slowly decrease trim (down) till it arms. Mine is trimmed about half way down.
