E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
mcx mod question
Old 08-30-2009 | 11:43 AM
Default mcx mod question
I know it's been discussed before but how much should I cut of the frame to get the board to lean back for faster forward flight.
Old 08-30-2009 | 04:37 PM
Default RE: mcx mod question
Nip about 1/16" off and push the board back against the post you cut off. If it looks good, put the screw in. If you need a bit more, trim it again. I cut 1/8" off and that was a bit too much. I put a cardboard shim between the board and the post. If you cut off a bit too much that will fix it.
