cx3 problem help!!!!!!!!!!!
CT
I AM HAVING SOME PROBLEMS WITH MY CX3. I WAS FLYING IT ONE DAY AND THE BLADES CROSSED AND ENDED UP CRASHING INTO THE GROUND. I REPLACES BOTH SETS OF BLADES, FLYBAR, AND INNER SHAFT. IT TOOK ME A COUPLE OF DAYS TO GET IT FIXED. I WAS ALL EXCITED TO GET IT RUNNING. I FIRST STARTED OUT BY TURNING ON THE TRANSMITTER THEN PLUGED IN THE BATTERY, LIKE YOU ARE SUPPOSE TO DO. I SET THE THROTTLE TO HALF WAY THEN CHECK THE BLADES. EVERYTHING WAS FINE UNTIL I WENT TO SHUT OFF THE THROTTLE.......IT WASN'T SHUTTING OFF. THE THROTTLE ON THE TRANSMITTER WAS OFF BUT THE BLADES WERE STILL TURNING AT MEDIUM THROTTLE. I HAD TO UNPLUG THE CX3 TO SHUT OFF THE BLADES. I TRIED REBINDING IT. IT DID THE SAME THING. I AM THINKING I MIGHT NEED A NEW RECIEVER. ANY SUGGESTIONS AT ALL????? I ALSO PUT IN NEW BATTERIES IN THE CX3 AND THE TRANSMITTER.IHAVEMADE SURE THAT ALL THE TRIMS ARE DOWN AND THE BLADES STILL SPIN AFTER THROTTLE UP. IT SEEMS LIKE IT LOSES COMMUNICATION WITH THE TRANSMITTER. ? ANYONE HAVE ANYHTING i CAN TRY?
I WILL TRY TO POST A VIDEO TO SHOW YOU FURTHER
Also the trim is allthe way down too
