E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Death of MSR?
Old 01-05-2010 | 12:51 AM
Default Death of MSR?
Hi folks, I'm worried... my MSRhad an epic crash recently (among other issues, the recepticle for the main motor snapped off the 5in1). I set down to glue & fiddle with the thing ... had transmitter on & commanding a bit of throttle so I could determine whenI had a good connection to what was left on the board. Repeated this process lots of times to get the spot right, all the while checking servos to make sure the heli was still tuned in.
After unplugging it for a bit to mess with some other chunk, I re-powered it and the unit would not connect to the transmitter, even after several attempts to re bind. And several batteries just for good measure. I tried varying distances betweent the two, re-positioning the heli... nothing but rapid blinking.
Has the 5 in 1 finally thown in the towel?
RJS
Old 01-05-2010 | 06:28 PM
dknovick's Avatar
Default RE: Death of MSR?
ORIGINAL: spagoziak
Has the 5 in 1 finally thrown in the towel?
RJS
I have no experience with binding, but that seems weird. Is there anyway to reset (to the factory default...?) both systems (TX & RX)?
-Dave
Old 01-05-2010 | 06:40 PM
RJS,
Make sure your throttle trim is centered.. Another weird thing, but try this. Power up the TX, then install battery to heli. Wait a few seconds, and if it still doesn't bind.
Move your throttle stick full up and full down, two or three times.. If that doesn't help, it could be the 5n1.
Dave
