E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
MCX problems
Old 01-06-2010 | 10:40 PM
Default MCX problems
My MCX used to fly great, until today. I'm having a strange problem.
First, sometimes it can't get enough throttle to lift off. I unplug it, plug it back in, it lifts off, and flies fine for a few seconds, then it starts to spin whenever I raise the throttle fast, and then if I keep flying, it starts to lose power again. Both motors get real hot, whereas before I could barely feel them getting warm. Also, the gyro is acting like a heading hold gyro...if I turn the MCX with my hands with the battery plugged in and the throttle down to zero, the motors spin a bit, as though trying to compensate.
Is my 5 in 1 dying?
Old 01-06-2010 | 10:41 PM
Default RE: MCX problems
Have you crashed it?
Old 01-06-2010 | 11:03 PM
Nothing more than the normal hard landing. It is all trimmed out and flies nice when not acting up as described above. Why, what do you suspect?
Old 01-07-2010 | 01:08 AM
JB-Heli's Avatar
Do your blades spin freely?Our little MCX got some hair wrapped around the rotor shaft and it had the exact same symptoms you describe. Took the inner shaft out, cleaned it and it, put it back together and it was as good as new. Could barely see the hair when it was together but very evident once taken apart.
Old 01-07-2010 | 01:36 AM
JB-Heli, I am very fond of you right now. Yes, that was it. Took it out, flies good as new. Thank you so much!
