Convert CP PRO to AR6110
My Blade CP Pro has original 72mHz receiver. I got the old receiver out. The new receiver is AR6110. Does anyone know the corresponding connection. The old receiver has Chl number 1-6 and the new receiver has THRO, AILE, ELEV, RUDD, GEAR, and AUX1. I figure all out except the External Gyro Gain connector goes to GEAR or AUX1 channel. Then what about the 6th wire for additional Aileron channel from chl 6 goes to GEAR or AUX1 channel. I am confused need help if anyone done this mode before. I also need some additional help on setup the DX7 transmitter for D/R and EXPO plus Stunt Mode to do the 3D later on.. Thanks
I still have copies of original spectrum setup sheets for cp pro.
I can email them if you give me your e mail.
The gyro goes into the chanell you set up in the DX7 menu, usualy the gear channel.
The pitch or third cyclic servo goes into aux 1.
B
B
