blade tandem rescue need more mAh
NY
can i use a higher mAh Li-Po battery then the 250 that comes with blade tandem rescue
because the 250 don't give much flite time
GA
RE: blade tandem rescue need more mAh
Do not know of any batteries that will work with it other then the stock battery. How much flight time are you getting? How long have you had it? Do you shut it down before the LVC kicks in?
NY
flight time about 4-6 mins but not timing them i got 3 batters
the LVC kicks in all the time lol too much fun
what i need to know how much mAh can the 4-1 controller handle
i should ask e-flite or Spektrum RC that question
NY
timed my 250's last night just one cycle and got 6.5 on batt.#1 , 7 on batt.#2 , 6.5 on batt.#3
time flys by when have fun
i need to get a better charger
one that can charge all 3 at the same time
