Blade 400 Binding and Bind Plug help.
AB, CANADA
I was watching the horizion video on taming the 400 down (and i made the adjustments to my DX6i with a new mode)and at the end he said you have to insert the "bind plug" and reconnect. i have the plug and i know where to put it but do i have to go through a binding process now because i made a new Model entry on my Transmitter???
Yes, the DX6I once bound a receiver will only operate on the last model memory taught to that receiver. That is if you bind the DX6I to your Blade 400 on model memory 1 and then create a new model memory with different settings(or the same settings for that matter) on model memory 2 then you need to bind to model memory 2. You can not switch back and forth without binding again. So if you want to go back to model memory 1 after binding to model memory 2 you must rebind model memory 1 and vice verca. You can have up to ten different model memorys though. You just can't have more than one model memory bound to the same receiver.
