cx2 wont fly in any direction need help?
my cx2 doesnt want to fly in any direction the swashplate moves the way its supoused to but instead of moving the lower rotor head. it moves the whole inner shaft
and the gears im not really sure what the problem is but i can get the rotor head to move the blades like it usaully does it moves the shafts up and down. need helpp<input type="hidden" id="gwProxy"><!Session data></input><input type="hidden" id="jsProxy" onclick="jsCall();" /><div id="refHTML"></div>
PA
can you put that in pictures or video ?
(sounds like your set collar is loose ... but it requires more than this description to dare try to diagnose ....)
