RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   Vibration / Stabilisation Problem Blade Cx2 (https://www.rcuniverse.com/forum/e-flite-helicopters-447/5347844-vibration-stabilisation-problem-blade-cx2.html)
Diastro 01-30-2007 08:24 PM
1 Attachment(s)
Hi all,
I'm new here, and I wanted to tell you all that's its a very nice place!
Soo here's the deal, last week I crashed my Blade Cx-2 and I broke my Inner Shaft Head. Soo i change it for an aluminium one. Then when I went for a fly, My heli kept moving on it self to the left side ( Rotating ) not a lot but still... Should I mention that all my minor adjustement button are to idle... Add to that when I start my motor ( bery slow speed) my lower blade start rotating before my upper one ( That's why it keep rotation to the left ). ALSO when my motors are at very slow speeD (when my heli is still on the ground ) I can see my heli "shaking" a bit. I can see that the outer shaft looks to be the reason why...
I started to dessasemble my Cx-2 tonight and and other prob came up, CAN'T Pull out my outer shaft cuz of a screw ( look at the pictures ) I wounder that maybe some of you guys might know how to put it out and also if some of you think that the prob is coming from an other part, might be helpful to tell me :)
Thx to all of you
bzinfinity 01-30-2007 08:41 PM
RE: Stabilisation / Self Rotation Problem on Blade Cx-2
Yeah, just remove that screw from the shaft retaining collar (the silver thing) and the whole thing slides off the top of the outer shaft.
Pull the outer shaft down through the bottom of the body, be careful not to lose the bearings.
Check to see if it's true. (Hint - if you have a hard time getting it out of the bearings, it's probably not true.)
Buy a new one, and lube it just a LITTLE bit, like a thin film, with some sort of machine oil from your LHS and you should be good to go! Also, I'm pretty sure my lower rotors spin first also, will have to check on that.
Bryan
LowKey3D 01-30-2007 08:43 PM
I had shaking that looked like a bent shaft but it was a heavy blade.
Check your blades. If they are from different parts bag they maybe out of balance.
I had this happen. Old upper blade had a small number 4 near the head and the new blade had a
number 3. Swapped the blade with the 4 on it with one that had a 3 on it and shaking
went away.
Diastro 01-31-2007 05:42 PM
Hey all,
I tried to start the motor to see if the Outer Shaft rally was bend but it seem like it isn't. Even tough I got a "kind" on vibration comming out of it... Also, I wanted to know if anyone had that "little vibration" effect and also if for everyone the lower balde start first....
Thx @+
BTW Thx for the quick response all.
shamos69 01-31-2007 06:20 PM
Hey Diastro......with mine, there's a ever so slight vibration but once the shaft reaches higher rpm it disappears.....one sure fire way to test the shaft for bends is to completely remove it from the heli and roll it on a smooth surface and get down to eye level with it....can't go wrong that way.
As for the lower blade starting first, same with mine but it's jus for a millisecond or two before the upper and i have my pots tweaked perfectly.
Diastro 01-31-2007 08:12 PM
Hey thx for the info...
I've fix the nose movement ( with the 4 in1 a couple of min ago now this part work ) but my head keep vibrating quite a lot. It vabrate soo much that if I'm at about 30 cm of the ground, my tail start shaking and goign left to right ( very fast ) then if I'm going to higher RPM then it desapear but its a very big vabration.
Hope Someone will be able to help :S
Thx
Diastro 01-31-2007 08:33 PM
1 Attachment(s)
Hey
I've try to see if my Flybar was bend and actually it was a little... When I'm rooling it, there's a siede when the middle is about 5-6 Milimeter higher then the other...
Do you guys think that it might be the problem?? Could it be why it vibrates???
Thx
DirftTech 01-31-2007 08:37 PM
RE: Vibration / Stabilisation Problem Blade Cx2
The flybar could be it, as for the shaking in the tail it sounds like your gyro gain is set to high.
choppersrule 01-31-2007 08:57 PM
Diastro,
Straight flybars on the CX2 are very critical, either try to make it perfectly straight or replace it. These helis are small and anything just a tad bit out of alignment will cause major problems.
Dave / Choppersrule
ORIGINAL: Diastro
Hey
Thx
Diastro 01-31-2007 09:56 PM
All right, thx
but just to make sure ( Don't want to buy a new Flybar for fun .. ) when both of my propeller were down and the was just the outershaft, I could fell a bit of vibration a low RPM ( even a bit @ high one, my heli frame moved on my desk... ) is it normal?
Thx
choppersrule 01-31-2007 10:59 PM
diastro,
Just for fun, try..... take all the blades off and spin it up, (leave flybar on) if stll vibrating, good chance the flybar is a tad out of balance.
Dave / Choppersrule
ORIGINAL: Diastro
All right, thx
Thx
papa38 02-01-2007 07:16 AM
If you guys really want to balance this heli, you need to take the inner shaft w/flybar, link, and upper blades attached,and balance them as a unit. I know, the flybar has a little slop in the holes, and it will take a little while to get both sides the same, but it is well worth it, and way better than balancing them seperately.That 2 gram link arm to the upper blades, at 1600 rpm will throw a wrench into the works, see?! 1 inch or so off the center of the shaft, at high rpm has got to have an effect on balance. Don't get me wrong, I got one at x-mas, and love it, they fly good out of the box, but if you go through it and "blueprint it" they are awesome.Oil all contact points (balls and arms, shafts)I oil everything except the gears, and the flybar, it's loose enough. And carefully balance all rotating assemblies as a unit, and you will have a most awesome flying machine!No binding in the shafts is a must!!! You can have slightly bent shafts without much binding, so be aware.If everything is balanced, you shouldn't have much shake at any rpm.
Diastro 02-01-2007 05:24 PM
1 Attachment(s)
Ok but finally i Think its not the flybar... I've but every thing away and even just with the outher shaft, the heli vibrate... I think the outer shaft is bended but not sure....
Does something like this ever happen to anyone of you guys?
BTW HOW DO I GET THE LITTLE SCREW DOWN THE OUTER SHAFT OUT!! I'ts like if it was lock1!
Diastro 02-01-2007 08:32 PM
Any tip on how to get that screw less tight???
p01rogue 02-01-2007 10:08 PM
Seriously , just use a bigger screw driver.
Even if it has lock tight on it , it should not be hard to get out.
Or,
Take it to your local hobby shop, I'm sure they would be happy to help.
Or,
Worst case scenario, drill it out and replace the locking collar and the shaft.
davidgeorge212 02-02-2007 01:00 AM
well I was going to make a post about how if i tweak it just right my heli's nose wont turn left or right but after that is worked out it seems to make small little circles while it is hovering in place. It keeps pointed in the same way but now that I read some of these posts i think it might be do to a bent fly bar that makes it hover arround in slight circles.
davidgeorge212 02-02-2007 01:58 AM
I really dont know what is the matter with mine. I have been flying mine for a couple weeks now and i have been able to hover pretty good but lately my heli has been starting to do this funny circular thing that i dont know anything about. The nose stays pointed in one direction and the whole heli just starts ocilating in a circle sometimes big sometimes small, i can usually correct the helicopters circular movement with stick control but i would like to know how to fix this problem. I checked everything in all these posts. the blades are ballanced well, i straightened the fly bar pretty good, they are both the same number blade. If anyone can help me id appreciate it.
thanks,
david
Diastro 02-02-2007 08:05 AM
Dave, try to put everything out of you Outer shaft and then make it s[pin if it vibrate its because it is bended... Otherwise you can try to adjust you 4-1 unit...
tibroc 05-22-2007 02:16 AM
ORIGINAL: davidgeorge212
thanks,
david
It sounds like your getting TBE to me. sometimes it can be a big circular movement and sometimes small. to fix it on the cx2 can be hard sometimes but here are a few things to try. Make sure your flybar is very very loose I mean loose. when you push down on the bar it should go up and down a few times. A little light oil on the upper head where the flybar ball link is can help. next check the freedom of movement of the upper blades they should move very easy a little oil there could help too. Make sure your swashplate did not get damaged they can start to pull apart after a crash. Look very close it can be hard to see the damage. last try new blades it can just be a bad blade or 2.
Hope this helps.
you can reach me at cx2parts.com if you need more help with your heli.
Steve
DrunkYoda 05-22-2007 07:57 AM
Please attempt to look at this doc it has a lot of the answers for TBE or Golly Wobbles.
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
DY
PS Thank Soloboss.
