RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   damaged 4 in1 ? (https://www.rcuniverse.com/forum/e-flite-helicopters-447/5375007-damaged-4-in1.html)
bulls 02-05-2007 03:56 PM
damaged 4 in1 ?
Hi
How does one now if the 4in1 unit is ng ,not working properly.
My pot trim does seem to make any differance in the flight when turning the little screw
one way or the other,No change . Any ideas anyone Thanks.....
almaidah 02-05-2007 04:05 PM
RE: damaged 4 in1 ?
if you make an ajustment on the pot make sure you remove the battery and then reconnect it after you set the pot if you done it that way already then you might to check your tail motor. let my know if the first test works
bulls 02-05-2007 05:27 PM
RE: damaged 4 in1 ?
HI
Thanks , but no tail motor ,cx2.
