CX2 battery - TP205 Balancer
Can someone please advise a source and the part number of the adapter cable needed to connect the E-Flight CX2 battery balancer plug to the Thunder Power TP205 balancer?
Thanks! |
RE: CX2 battery - TP205 Balancer
http://www.commonsenserc.com/product...products_id=88
http://www.commonsenserc.com/product...roducts_id=198 According to Common Sense, these should do it... |
1 Attachment(s)
It works perfectly!
The only thing I don't like is the connector adapter block into the TP-205 is a (3) pin...the TP Balance Port is a (4) pin - so you have to be careful to connect it to the correct pins in the Balancer! You must reverse the polarity! |
| All times are GMT -8. The time now is 04:57 PM. |
