vortex cx2 motors????
hi i was flying my heli today that i got last week and notcied it has really lost alot of power so i decided my motors are going bad and i was wondering where the cheapest place to buy the vortex motors are i just need a couple replys
thanks for your times |
RE: vortex cx2 motors????
Someone said that the vortex motors perform worse than the stock CX2 motors. Stick with the stock ones or the Xtreme motors.
where can i get teh xtremes ive had bad luck with the stock motors also will the heat sink work on the xtreme motors and how much do they cost moneys really tight i rolled my truck 2 days ago
I used vortex motors as an upgrade and found they were no better than the cx2 stock ones so i would get the extreme 180 instead
ORIGINAL: crawlerking11 where can i get teh xtremes ive had bad luck with the stock motors also will the heat sink work on the xtreme motors and how much do they cost moneys really tight i rolled my truck 2 days ago |
May I also recommend BoomTown Hobbies. [link=http://shop.boomtownhobbies.com/main.sc]BoomTownHobbies[/link] Prices are good and customer service is excellent! Jamie is great answered my questions right away..
Can someone post a pic of theses vortex motors iv never seen them
No-one has asked the question - How old is your CX2? You say you have owned it for about a week?
If so, your Motors shouldn't be defective after just this short time! Have you checked all the usual places for Binding, that could be causing loss of power? I recently experienced reduced flight times, and blamed either the Motors or Batteries! Turned out the Outer Shaft was bent, causing binding also on the inner shaft, and draining the battery in no time! Worth the inspection, and could save you some $$ ! Anyhow, I'd recommend the Xtreme 180 motors if you do decide to "upgrade". Cheers. |
Ok got ya, have yall seen the new motors out, I found these at cx2parts.com or somthing, they look like the xtreme 180 but diffrent stickers and brand...
<a href="http://s212.photobucket.com/albums/cc151/SickRCboats/?action=view¤t=01IMG_5910.gif" target="_blank"><img src="http://i212.photobucket.com/albums/cc151/SickRCboats/01IMG_5910.gif" border="0" alt="Photobucket"></a> Are these good motors? http://i212.photobucket.com/albums/c...01IMG_5910.gif |
ORIGINAL: H3li No-one has asked the question - How old is your CX2? You say you have owned it for about a week? If so, your Motors shouldn't be defective after just this short time! Have you checked all the usual places for Binding, that could be causing loss of power? I recently experienced reduced flight times, and blamed either the Motors or Batteries! Turned out the Outer Shaft was bent, causing binding also on the inner shaft, and draining the battery in no time! Worth the inspection, and could save you some $$ ! Anyhow, I'd recommend the Xtreme 180 motors if you do decide to "upgrade". Cheers. yes, its not your motors. Last thing you should check would be them. 1. Check Blades. 2. Check shafts. 3. Gearmesh. 4. bearings. 5. Then motors. 6. Test 3-1. All the how to info is in here. Tips/Repair/Guides/Mods Links http://www.rcuniverse.com/forum/m_70...tm.htm#7035042 |
I too have had my CX2 for about 6 days nw and right out of the box my father in laws $70 Happy time hobbies Huey makes this thing look really bad....I've check and rechecked everything but the 3-n-1...hopefully when I return it tomorrow I get a nice new one
i forgot to say that my cx2 ips used i bought it used here in the callsifeieds the guy had no clue they were going bad cuz i didnt even notice it the first couple times i flew
i no its the motors because i have inspected everything and put in my buddies stock motors and it took right off but i had to give them back to him the next day |
| All times are GMT -8. The time now is 08:42 PM. |
