Help CX2 problem
Today I went to turn on my CX2 and the 3-in-1 blink red and green, I followed the manual and try to bind the unit again, however, even during the binding process the orange light stays blinking and the 3-in-1 light just blinks reb and green. Any help would be great? It fried?
Thanks, John |
RE: Help CX2 problem
Are you using the stock Tx that came with your CX2? Please explain how you are trying to re-bind. Maybe you are doing something wrong. Do you have the bind plug inseted into the BATT port on the AR6100e when you try to bind? List the steps you take and the order.
If you are doing everything correctly and it still will not re-bind, check the batteries in your radio and try again. |
Yes all is stock.
I'm installing the bind plug into the Batt of the Ar1600. Pluging in the battery (fully charged) blinking orange led and red and green flashing on the 3-in-1. Turn of the Lp5DSM reciever new batteries 5.9 volts on the unit. never seems to bind after that? Never had a problem with the unit for 2 months until today. Thanks, john |
Can you have the crystals the wrong way round in a cx like in some others ?
ORIGINAL: Coyote64 Can you have the crystals the wrong way round in a cx like in some others ? |
Thanks Guys so what do you think, If you can not get the 3-in-1 to stop blinking red/green is it bad?
John |
ORIGINAL: eat2muchrice ORIGINAL: Coyote64 Can you have the crystals the wrong way round in a cx like in some others ? |
ORIGINAL: Coyote64 ORIGINAL: eat2muchrice ORIGINAL: Coyote64 Can you have the crystals the wrong way round in a cx like in some others ? |
Happy B-day.
ORIGINAL: jtm311 Thanks Guys so what do you think, If you can not get the 3-in-1 to stop blinking red/green is it bad? John Can you try binding to a different Tx? If it doesn't work, then you can assume that it is the Rx. |
I also have the CP model which Need parts would you know if I can try it with that RX?
Turn the throttle AND throttle trim all the way down and try again. That could very well do it.
Gary |
Thanks Gary I also tried that one first. [:o]
Is there a way to test the Ar1600 with using the 3-in-1? John |
| All times are GMT -8. The time now is 01:30 PM. |
