cx2 rx channel problem
Hi guys,
I got a esky Douphin fuslage meant for a lama4 and squeeze it into a cx2. The fuslage came with a LED and after plugging it into the spektrum ar6100e "Gear" Channel, the cx2 glitch like crazy when throttle. I checked the wiring, everything is in order. Only after unplugging the LED connector everything is fine. Is this right ? or do i have a faulty rx ? I read somewhere the cx2 suppose to be a 5ch tx. is there any mixing done on the tx ? Thanks |
RE: cx2 rx channel problem
Are you sure you didn't plug it into the signal pin on the gear channel and only in the 5V and ground pins?
Nick |
ORIGINAL: evdreamer Are you sure you didn't plug it into the signal pin on the gear channel and only in the 5V and ground pins? Nick |
| All times are GMT -8. The time now is 06:21 AM. |
