gyro
looking for a good cheap head holding gyro. and can u use a gyro made for a tail servo on one with a tail moter?
RE: gyro
Yeah you can use a gyro with a tail motor driven tail, but are you talking about the CPP? Because the only known gyros that work with the CP+ and CPP are the G90 and G110. But if you use a brushed speed controller for the tail motor then you can use any gyro you want.
Nick |
RE: gyro
Yeah you can use a gyro with a tail motor driven tail, but are you talking about the CPP? Because the only known gyros that work with the CP+ and CPP are the G90 and G110. But if you use a brushed speed controller for the tail motor then you can use any gyro you want. Nick Uri |
RE: gyro
Uri,
Thanks for the info. I just have never heard of anyone using the Telebee gyro before. But I do know the Futaba GY240 and 401 will not work. Nick |
RE: gyro
ORIGINAL: evdreamer Uri, Thanks for the info. I just have never heard of anyone using the Telebee gyro before. But I do know the Futaba GY240 and 401 will not work. Nick |
RE: gyro
Is there no way to set up gy240 using the stock esc on CP Pro? Do you know why this can't be done? Nick |
RE: gyro
ORIGINAL: evdreamer Is there no way to set up gy240 using the stock esc on CP Pro? Do you know why this can't be done? Nick |
RE: gyro
This is the ESC I used when I had my CPP with a GY240.
http://www.eboyztoyz.net/index.php?op=showitem&sku=2334 Just unplug the red wire out of the throttle connector on this ESC before plugging it in the GY240. Nick |
| All times are GMT -8. The time now is 10:51 PM. |
