Anyone running Blade 400 with Align 430x motor
I need help finding the right pinion for the align motor to work with the blade 400. It has a 3.14mm shaft on the motor and according to my calculations it needs a 9 tooth pinion to spin the blades at 2200 rpm.
I can't seem to find that pinion anywhere. |
RE: Anyone running Blade 400 with Align 430x motor
Did you factor in inefficiencies of the motor and friction? You probably get around 85% max efficiency. Then with old batteries the headspeed will also be slower. You could also lower the throttle curve to get the headspeed you need with a 10T or 11T pinion.
Nick |
I have a 15 tooth pinion on it now and it is way to high of a head speed. The main gear on the blade is 145 tooth I believe the motor is a 3550kv outrunner and I am running a new 3 cell lipo.
I'm running the 430XL motor in my blade. i used a 11 tooth pinion. I did this because there is not enought metal in the smaller count pinion due to the larger 3mm shaft. I think that your target of 2200 rmp is way to low. You need 2800 to 3000 and the heki will be more stable.
ORIGINAL: gunnarjohn I have a 15 tooth pinion on it now and it is way to high of a head speed. The main gear on the blade is 145 tooth I believe the motor is a 3550kv outrunner and I am running a new 3 cell lipo. which i seriously doubt the head or blades can handle that speed thats actually pretty dangerous,i would keep my head low when flying that heli, parts may just become projectile`s. if i remember correctly the stock head is rate up 3200 rpm max. the stock motor is 3800 kv with a 10 tooth pinion. with a 3550kv motor i would say a 12 tooth pinion would be optimal gear to rpm match. this will keep the motor at 80% throttle effecience. which means not taxing the esc or head parts |
mrich are you running the stock esc with the 430xl?
I'm running the 430XL motor in my blade. i used a 11 tooth pinion. Any required mods? What throttle curves are you using? Thanks. |
Yes I'm running the stock ESC with the 430XL. The stock Eflite motor and the 430XL are close enough that there is no problem. I did have to ream out the motor mount hole slightly to use the Align motor but that took only a few minutes.
One advantage to the Align 430XL is that you won't rub the battery. This motor has a can cover. |
