Need a quick question answered on Mini Ultra Stick!
VA
I think I will pick one of these up tomorrow.
I have a question on the aileron setup Would you go a Y-Harness or put one of the servos on ch 6 reversed and mix? ( think this is the right question?) I have a 9CHP, and will get maybe a R146IP receiver? Will be getting the E-Flite S75 Servos.
Any other tips on what ot get with this are welcome!
My Feedback: (13)
MD
RE: Need a quick question answered on Mini Ultra Stick!
I did not use the Y-harness, but let the radio do the mixing. This way I can use flapperons and aileron differental. But honestly it didn't need either. I wouldn't spend the extra $8 to $10 for a Y-harness when the radio will do the job for you.
VA
another vote to use the radio. another nice thing is setting up trims, epa etc on each servo individually while setting up the plane.
VA
I got the MUS today. Everything in the box looks great. A few control horns bent over a little, but no damage.
I am using the E-Flite PARK 450 BL OUTRUNNER MTR,890KV [EFLM1400]
I have a question. When puting this on the mount that comes with it, do you use Locktite on the 4 screws? Red or Blue?
The props I got for this (10 x 7 slow flyer) will not seat on the shaft so the collet will grip the motor shaft. I will have to drill them out.
VA
I asked the owner of my LHS the same question about putting Locktite on the motor mount and he said since there is no vibration it's not necessary. I didn't use it and after around 20 flights, everything is still tight. I've got an E-Flite 450 outrunner on mine and it's a blast.
ID
here is my mus guys I set mine up with the 480 outrunner and a 20 amp esc and a 2200 mah battery turning an apc slowfly 10x7 prop unlimited vertical and great aerobatics
Would a Mini Ultra Stick be a good 2nd electric plane? I have covered all of the basics with a Hobbyzone Aerobird Challenger.
(to all)
(to all)
My Feedback: (31)
NJ
ORIGINAL: gforeman
