E-Flite Mini Pulse XT Owner's Club
#1601
RE: E-Flite Mini Pulse XT Owner's Club
For those with Phoenix flight simulator- Help please.
I am learning to fly this plane and in the simulator i am using the katan electric, which i have edited to as near the mini Pulse as i can get!
I am having difficulty taking off with the real plane ,which has a lot of torque sending me left, as i throttle up.
I am trying to reproduce this on the Phoenix simulator, but the plane takes off quite straight.
Does anyone know which parameters to change in the "Edit aircarft" part of the simulator , to reproduce this veering left scenario?
#1602
MO
I love the MP, but I am wondering what other planes people have flown that are similar or better. I love how stable and easy to land this plane is while still being aerobatic enough to keep things interesting.
#1603
ORIGINAL: derek2005
#1604
ORIGINAL: GoldKraft
This may surprise you....but I just flew a friends Precision Arobatics Extra 260.....it has the stability and light flying ability that the MP does .....but it will do much ,much more including 3d. It is even easier to land than the MP. I liked it so much Im buying one this week. Its one plane that can fly pretty patterns like the MP or get real crazy like my MUS.....PLUS 3d. 48" wingspan(490 sq in.) and 33oz all up wieght....it dont get no better than that!
It's a very impressive plane. Carbon-fiber and balsa construction make it very light. The servo rods are even carbon fiber and the rudder linkage between the servo and rudder is a pull-pull kevlar cord - again, very light. You can see it at www.extra260.com.
I love my MP - I even have two - one with the PNP engine and one with the 480. The extra 260 seemed like the next progression for me from the MP.
Bert
www.photobert.com
#1605
ORIGINAL: bertsirkin
Bert
www.photobert.com
Bert
www.photobert.com
fixed the link www.extra260.com
#1606
MO
Funny that you all say the same thing. After posting I went to atlanta hobby and saw the exact same plane and thought it looked awesome. I may just have to pick that one up.
#1607
QC, CANADA
video this morning with a cam onboard Mini Pulse XT
http://video.google.com/videoplay?do...44474714035897
#1608
MO
I have the PNP MP and I was wondering if anybody else that has the PNP upgraded the servos. Especially the Elevator and Rudder. It seems like the stock servos have trouble re-centering after use in either direction. They also seem slow and weak. I didn't expect them to be great, but now that I can fly decent, I am wanting better response.
What would a good choice of servos be. I don't need top of the line, but I would like something faster, stronger, and more accurate. I am still somewhat new to planes so I am not sure what servos are good in them. I prefer JR and HiTech equipment.
ORIGINAL: derek2005
ORIGINAL: derek2005
MO
Thanks for the replies. I will probably go with the 65's. I would rather have the torque than find out I may have needed it when it is too late. I sure to like flying this plane. I am surprized with how easy inverted is. I can land it very smoothly now as well. What a great plane!
#1612
ORIGINAL: derek2005
just make sure you re-set all your dual rates and expos,
i didnt do that after switching over from the s75's and the hs65's rolled my plane wayyyyyyyyyyy too fast!
#1613
MO
Thanks for the tip! I'll be picking up my 65's on Thursday!
yesterday, I did my first cross wind landing! Not much of a crosswind, but enough to make me think twice about doing it. All went well. I just kept the wind side wing a bit lower. This is such a fun plane to fly. My favorite thing to do right now is to take it up with a bit of wind and dead stick up high to see how long I can keep it up and how slow I can fly it. Then I turn around do some aerobatics and repeat!
Happy Flying!
Happy Flying!
#1614
NJ
Would I be all right using the ParkZone 3S 1800mAh and 2200mAh batteries from the T-28 Trojan in the PNP version of this plane? I noticed that they are similar in size and weight to the recommended Thunder Power 2100mAh but the continuous discharge rate is slightly lower. Any guidance on this matter would be greatly appreciated. I am relatively new to the hobby and have a HZ Super Cub and the ParkZone T-28 and I'm really interested in purchasing this plane. I'm just trying to save a little on batteries and I figured if I could use the 3 that I already have for the T-28, I might only have to purchase 1 more instead of 2 or 3. Thanks in advance for any help you guys can give me.
#1615
GA
I don't see any reason why you would not be able to. I plan on doing the exact same thing, since I just got this bird. Just make sure you have all your connectors standardized.
#1616
NJ
Thanks for the response. I guess it's off to the hobby shop for me. By the way, does the ESC that comes with the PNP have the Eflite connectors like the T-28?
#1618
NY
Just purchased a e flite mini pulse pnp...When i opened up the box the speed controller was just danglin around and the 2 way velcro was not on anything,just on the speed controller...Does anyone who ownes one can tell me where the speed controller goes...On the box it looks like it goes up against the wall where the battery goes but i am not sure if i should put it there....Thanks..
Dan
Dan
#1619
CA
#1620
NY
Anyone know where the speedcontrol goes in the mini pulse xt....it shows on the box it came in is right on the side where the battery goes....Thanksss
#1621
NY
On my mini pulse when you put on the white spinner on and turn on the motor the spinner does rotate but kinda virabrates,so i am just wondering if i can use the the motor adapter and the silver propeller nut instead of the adapter and the white spinner cone..
Danny
Danny
#1622
ORIGINAL: dbgood
Danny
Danny
Yep....spinner is only for looks.
#1623
CA
#1624
CA
I just got back from the maiden of my new Mini Pulse XT. I went with the ARF version and a Park 480 1020kv, Eflite 40A esc, APC 11/7 prop, 4 Hitec HS-55s, Ar6100, my trusty DX7, and used Flight Power Evo 25 3S 2170 packs. I also ditched the stock Eflite spinner and used a [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRBA9]Great Planes 1-3/4 inch spinner[/link] with an APC prop. Everything came back in one piece and the plane flew Super. I flew three packs through it and had a blast. It only needed a couple of clicks of aileron trim and it flew straight and leve. I flew the entire first pack on low rates and then switched to high for the final two packs. The plane did everything I wanted it to like roll quickly, snap roll VERY quickly, fly inverted nicely, and most of all unlimited vertical! I was even able to pull of some very sad looking knife edge passes on the last pack. Overall the plane was not as fast as I had expected. I think my T-Rex 500 is actually as fast or faster than the MP with a 480 and 11/7 prop. All in all I give my new Eflie Mini Pulse XT a big .
