something w/ flaps and retracts?
MD
So I finally broke down and bought the new Dx6I 2.4 radio. I'm going to add flaps to my MUS but I really want something I can use all 6 channels on. Electric, MUS size or smaller, basically needs to be a relative parkflyer. You know how it is, when you get that craving to get a new plane. I was leaning toward http://hobby-lobby.com/spitfire.htm I know there are no flaps, but it wouldn't need them and I love the Spitfire, beautiful airplane. But I am totally open to suggestions, so bring them on!
CA
RE: something w/ flaps and retracts?
GWS has some planes with retract options. They're all foam and great flyers. The retracts are so-so. The P-51 I know for a fact can be built w/ retracts. Not sure about the Spitfire.
I know this is not the answer to your question but there is really no point in using seperate flaps on the MUS. You have a flaperon option that will
accomplish what you want without adding the extra servos which would require a BEC to be added as well. The only reason to add the flaps would be for crow function which requires 7 channels. I suppose you could do some elevator to flap mixing if that is what you are after....I actually tried the e to f and didnt care for it on mine.
MD
I'm not sure the 6i does flaperons or am I mistaken?? And no problem off topic is usually much more interesting than on topic
MD
Right and one other question, I just all the stuff in and wired it all up already. I was not using a bec exactly, not separate battery. I am using a 20 amp esc. Would you recommend a separate bec w/ it's own battery?
