Ypgtading Li-po oack can I keep the same ESC
CA
I am upgrading the Lipo pack on my WM Mustang. It has a 400 brushless motor and a 30Amp ESC. If I go to a 2450mah 3Cell 30c battery instead of the 2150mah 3cell 10c I am using now would I need to change the 30A ESC. The motor is the brushless outrunner that came with the Model. I also have a 2200 mah 3cell 20c Li=po pack will that also work with the 30A ESC.
AZ
RE: Ypgtading Li-po oack can I keep the same ESC
I agree with DR_chuckie, however, be aware of the weight change. Even a small increase in battery weight will affect the flight characteristics.
CA
Somtimes for little warbirds it makes them fly better. They cut through the wind better but you have to add a little throttle when comming in to keep it from a hard landing. I think the 2450mah battery is around 7.7 ounces.
