Electric Twin set up
AB, CANADA
I'm new to electrics and would like to set up a twin engine electric otter with differential motor power when on the ground. ie. turn left the right motor powers up more, I think you bind the motors in seperate channels and associate with the rudder in fight mode? I've got a JR 9303 radio and think it is done with flight modes some how. I'm sure this question has already been asked. Maybe someone in the know could redirect me to previous post on how to set it up. I've got several twins that I'd like to set up this way.
Art
Art
FL
RE: Electric Twin set up
Yep can be done, I do it om my P-38's. Also try it in the air, at least on the 38's it also helps using differential in turns as it reduces yaw, and the plane can make tighter turns.
Here's how I do it.
To program differential thrust, begin by setting up one of your program mixes for dual throttle. Plug a spare servo into channel 3 of your receiver and a second spare servo into one of your AUX channels. Set your mix with the throttle as the master and the AUX as the slave. Set this mix as always “on” by choosing any switch and the “null” position. Use 100% for the mix amount. Verify that both servos move in the same direction and move the same amount from idle to full throttle positions.
Next set up a second program mix with the Rudder as master and Throttle as the slave. Choose a switch to activate this function and use a mix amount of 25%. Verify that the servo in channel 3 moves toward the up throttle position when left rudder is applied and toward down throttle when right rudder is applied. If not, change the mix amount to –25% and test the movement again. (Leave link OFF so that it doesn't try to command the aux2 servo to move also.)
Finally set a third program mix with the Rudder as master and AUX as the slave. Choose the same switch and position that you used for the second mix and again use 25% for the mix amount. Verify that the servo in the AUX position moves toward the up throttle position when right rudder is applied and toward the down throttle position when left rudder is applied. If not, change the mix amount to –25% and test the movement again.
Now we are ready to check the programming on the plane. Plug the right hand motor ESC into channel 3 and the left hand motor ESC into the AUX channel. Turn off the switch that controls the differential thrust mixing. Turn on your radio and plug in your batteries to the ESC’s.
First, verify that the throttle control operates both motors in normal fashion. Hold the airplane securely and move the throttle stick from idle to full power. Both motors should track each other from idle to full bore. Now set the throttle stick to the idle position and switch on the differential thrust-mixing switch. Slowly advance the throttle until both motors barely begin to turn. Now move the rudder stick to give full right rudder command. The left motor should speed up and the right motor should stop. Left rudder command should cause the right motor to speed up and the left motor to stop. Taxi test your model, switching the differential thrust “off” and “on” to test the effectiveness of the 25% setting. If you have a paved runway, you may want to reduce the mix amount to 15%.
Here's how I do it.
