Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Techone Mini F18
Old 02-19-2012 | 07:48 AM
Default Techone Mini F18
I am building the Techone Mini F18. How do you set it up to the Dx6i transmitter ? Any build tips and viedos would be helpfull.[sm=spinnyeyes.gif]
Old 02-19-2012 | 08:06 AM
Default RE: Techone Mini F18
Hey Leo,
that's a pretty broad question- do you have something specific you're looking for?
Solo
Old 02-19-2012 | 08:22 AM
The build instructions say " "AILVATOR" is applied to this plane." My Dx6i does not have that function in the "Wing/Tail mix " settings. It is a profile pusher prop jet.The ailerons and elevators are connected by one pushrod on each side connected to a servo on each side. I have built a few planes an own some bind n flys but have not seen this setup before. How do I set it up to my Spectrum Dx6i?[sm=50_50.gif]
Old 02-19-2012 | 02:15 PM
Does the DX6i have elevon setup? That might be it.
Old 02-26-2012 | 01:19 PM
Yep flyinsolo is right it's in the elevon wing/tail mix,the ailerons and elevator will all act as an elevon wing/plane would.
As you haven't replied i take it you now know that but i thought i'd add this just in case someone else have the same problem,then after reading this thread they will know what to do.
Old 02-26-2012 | 03:29 PM
Yep that was right. Its built and runs right. If their CG is right it needs a bit of nose weight. Too windy today to try it and next weekend dont look good either.
