motor wont throttle up
I just put together the cmp katana SR plugged in the battery and for some reason the motor wont spool up. The servos all seem to work and the ESC is goes through its beeps and the motor pulses slightly with the beeps. I flipped the idle up and throttle hold switches on my futuba 6ex transmitter and run the throttle up and get nothing. Anyways I was hoping someone with more experience with electric RC can help out, I starting make the switch over from glow.
Does this particular esc need to be programmed, the last few I have used worked out of the box.
RE: motor wont throttle up
It's possible that you need to reverse the throttle channel as Futaba's throttle signal works in reverse to most other makes. You'll also need to teach the ESC the max & min settings of the throttle channel (instructions?) Don't have a prop on the motor until you've sorted out the problem....safety first!!
Not sure why you are trying to use throttle hold and idle up with a fixed wing model as you'd be using aero mixing rather than heli.
Hope this helps.
C8
Hope this helps.
C8
My Feedback: (16)
ORIGINAL: jeffk464
ORIGINAL: cubaneight
Hope this helps.
C8
Hope this helps.
C8
ORIGINAL: jeffk464
Ok the motor throttles up now but only when at about 3/4 throttle and then it spools up to full and isn't really adjustable. I guess I need to figure out how to teach the esc max and min without instructions.
Hope this helps.
C8
Hope this helps.
C8
Dido on cubaneight I have flown nothing but futaba and Electrics futaba MUST be reversed. (End points at 100% as said in other post)
Jeff
May All Your Landings Be Smoooooth!
Jeff
