Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Charger Recommendation
Old 07-17-2012 | 04:09 PM
Default Charger Recommendation
<span style="font-family: "Times New Roman","serif"; font-size: 12pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">I am switching to electric and would like recommendations for a charger/balancer for a 4400mAh 4S 14.8V G6 Pro Performance 45C LiPo</span>
Old 07-17-2012 | 04:52 PM
My Feedback: (325)
Default RE: Charger Recommendation
Hi, welcome to RCU. Allow me to make a few assumptions because you didn't specify.
(charge at max recommended rate and only doing one pack at a time)
4.4 x 8c = 35 amps and 16.8 volts is around 600 watts. I'd recommend the i-charger 306B , but you'll only get 30 amps from it. Beyond that there's FMA PL6 at 40 amps. Both available at ProgressiveRC http://www.progressiverc.com/chargers
Of course if you aren't in a hurry then numbers can be cut in half , quarters, eights, ect. On a budget maybe one of the many 200 watt 10 amp chargers or one of the many 400 watt 20 amp chargers will suffice.
