Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Electric Help Needed
Old 12-12-2012 | 02:36 PM
Default Electric Help Needed
I want to switch from gas to electric in a GTM Hanriot biplane it weighs 16 pounds now with a 30 cc gas engine. Having had little experience with electrics, I need help with motor size, ESC, batteries, etc. I do have 2 Stevens Aero models that I have been flying.
Any ideas would be appreciated.
Old 12-12-2012 | 07:03 PM
Default RE: Electric Help Needed
Well going only by the weight and easy to get setups. A Tacon 160 running 10s ((2) 5s 5300 ipos') spinning an APC 20x8 E prop should do the job nicely. gives a rough guess of 8 minutes of flight time. I have always gotten longer flight times then it predicts.
Motor
http://www.hobbypartz.com/96m608-big...335-245kv.html
Battery (s)
http://www.hobbypartz.com/98p-30c-5300-5s1p.html
ESC
http://www.hobbypartz.com/07e26-proton-100a-hv.html
Free online calc program
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz.
Edited for prop size.
Old 12-15-2012 | 06:44 PM
Buzz,
Thanks for the reply.
The Hanriot cowl is a 10"diameter. I'd like to use at least an 18" prop.
Old 12-16-2012 | 08:24 AM
Sorry about that. I need to go back and edit that post. It is a 20X8 prop!!!! So you should have plenty of power if I can type the correct prop size.
Buzz.
