Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Balance plug question
Old 12-14-2012 | 07:26 PM
Default Balance plug question
Tota newbie to electric. Purchases a Hyperion EOS6061i charger at the swap. Came with three balance boards but nothing my Life 2100mah 6.6V batteries will plug into. The battery balance plug has only 3 pins and non of the boards have only thee pins. Four or more. What to do?
Old 12-14-2012 | 07:57 PM
My Feedback: (30)
Default RE: Balance plug question
Does the charger itself have a 3 pin balance plug on it? You might have to just go without balance charging it until you can find a board with 3 pins.
Old 12-15-2012 | 05:07 AM
My Feedback: (325)
Your Hyp charger probably came with HYP balance board and 2-4s use the same white plastic housing. You will need to get the right board OR change your battery over to Hyp tap. It's hard to tell without seeing it or knowing the brand of battery , but my guess is that you need XH.
http://www.rcuniverse.com/forum/m_91...tm.htm#9108084
Old 12-15-2012 | 08:43 AM
Yeah, I bought this Hyperion charger and it came with these boards. One is marked hyperion and has inputs for 2,3,4,5 and 5 cell
The fewest pins are 4 even on the two cell location.
Same with other board that says thunderpower, flight power on it. Still no 3 pin inputs.
My batteries I just purchased are the LiFe brand from Hobbico. They have a 3 pin balance plug thats slightly different than any of the options I have on these boards.
Guess I will try calling Hyperion service? Thanks
Old 12-15-2012 | 10:56 AM
My Feedback: (325)
The TP should have 3 and 4 pin plugs , but they are different pin spacing anyways and a different latch. Your Hobbico Batts use XH style taps. They are the most popular.
Old 12-17-2012 | 06:24 AM
Your right and I have an XH board coming. Thanks all.
