2 Wire ESC
2 Wire ESC
I recently picked up a 3-D EPP YAK kit. I think it may have been laying around for a while. Anyway, it has a two wire motor. The recommended ESC was a GPMP 2020, a 20 AMP ESC which appears to be no longer available. Seeing how all the ESCs out there are 3 wire output to the motor, I was thinking that I could use a 3 wire ESC's Black wire to the Black wire on the motor and the two other wires to the Red wire on the motor. Could this work?
RE: 2 Wire ESC
If I read your post correctly, you have a motor with two wires. That means it is a brushed motor. If so, you need a brush (two wire) ESC. Any brush ESC rated for 20 or more amperes should work okay. You can not modify a brushless ESC to run a brushed motor.
