Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Receivers for E-flight
Old 11-03-2003 | 05:19 PM
Default Receivers for E-flight
Just curious to find out which receivers you all thought were good. I have a GWS 4 ch but am looking to go to a 6 ch. Any thoughts on GWS or any others? Thanks.
Old 11-04-2003 | 12:33 AM
Default RE: Receivers for E-flight
Hi,
GWS Rx normally have shorter range. Why not consider Hitec Super Slim (8ch), Electron (6ch) or Micro 555 (5ch)?
The feedback on these Rx are positive most of the time. I myself use the Super Slim. By the way, these are all light-weight dual conversion Rx & their effective range are around 1mile.
Old 11-04-2003 | 02:38 AM
My Feedback: (12)
The Berg5 is a great unit.. www.aeromicro.com has them w/crystal for $50
Old 11-04-2003 | 04:22 PM
2nd the Berg - simply no better available.
Shawn
Old 11-08-2003 | 09:17 AM
My buddy tried the Berg with his frequency synthesis Tx and found it does not work. Because of that I have stayed away from the Berg while the GWS works just fine.
Dan
Old 11-08-2003 | 11:30 PM
I also prefer the Berg. Mine has been rock solid.
Old 11-09-2003 | 12:03 AM
My Feedback: (12)
ORIGINAL: RCPilot100
Dan
If your friend would have read the instructions with the Berg, he would have read that it wouldn't work..wouldn't work with a Hitec module in a Futaba TX. It works with the Hitec module in a Hitec TX, but not a Futaba module in a Futaba TX. This is strange, but it's in the instructions...
Old 11-17-2003 | 12:14 AM
Abraxxas's Avatar
I am ready to build my first E-plane (fly glow and gas soon) and was wondering about the berg receiver, is this dual conversion? I am building a 3DX with brushless LiPo setup and wonder if this receiver would work good? Is dual conversion a necessity if flying around others or outside? Thanks for any feedback. I use the Hitec Electron 6 in a Funtana and it is great, thought about just taking one of those out of the case and heak shrinking it? But if a cheaper one could be comparable, I would be interested
Brian
Old 11-17-2003 | 07:28 AM
Matt Kirsch's Avatar
My Feedback: (21)
A properly designed single-conversion receiver is just as good, if not better, than any dual-conversion receiver out there. The Berg is a well-designed single-conversion receiver.
Old 11-21-2003 | 11:39 PM
aeajr's Avatar
ORIGINAL: azfrench
What are your objectives and what you flying?
Indoor? Outdoor?
Small field? Large Field?
Parkflyers? e-gliders? High speed ? Low speed?
GWS 4 channel has range of about 300-500 feet. The 6 channel is 1000 feet. Hitec Super slim 8, Electron 6 and Micro 555 all have ranges in excess of 1 mile.
If range matters, almost anything has more range than what you are using now.
