Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
EPP foam question
Old 12-09-2003 | 08:32 PM
Default EPP foam question
Hello, i saw in a video someone had an epp foam airplane, and he was able to bend the wings and fuselage to like 90* angles. Just wanted to know if this is the case for all epp foam, or if that was just some special type. Thanks.
Old 12-09-2003 | 11:53 PM
Default RE: EPP foam question
What you saw was a plane made with thin sheets of EPP foam (the Southern X2 or similar). The wing has EPP ribs covered with thin EPP sheet and the fuse has thin sheet EPP stiffiners. Most EPP planes are made with solid EPP and they do not bend as easily.
Chuck
Old 12-09-2003 | 11:59 PM
ahhhh, i see. Are solid epp planes still very durable? Will a moderate crash damage it, or do you really need to crash hard to break the foam body. Thanks.
Old 12-11-2003 | 12:38 AM
EPP foam in a solid structure is very durable.
Chuck
Old 12-14-2003 | 09:19 PM
wildthing7037's Avatar
Epp foam is extremely hard to break in a crash. We have been using them in slope gliders here for a while, and when combined with carbon fibre/fiberglass spars and covered in fiberglass tape produce a virtually indestructible model. Although Epp is usualy heaver when compared to white foam and balsa.
Stefan
