New Wing Prop direction help...
I'm new to this still and just built my first wing. It looks great and I can't wait until thee winds in AZ die so I can fly it... anyways.... I am confused about prop direction since it is a pusher. The Leading edge should be forward towards the front of plane and out the back? Then what direction is the prop supposed to spin? looking at it from the back.. clockwise or counterclockwise.. thanks.
From the rear, the prop turns clockwise. With a Zagi prop, the writing goes to the rear. With a Slinger prop, the writing goes to the front.
Later;
D.W.
Later;
D.W.
Front.
By the way. If you are an experienced flier, don't worry about the wind. This type of airplane flies very well in strong winds.
Later;
D.W.
Later;
D.W.
