FLOATS
RE: FLOATS
Fiberglass floats are better quality than foam floats. The slick finish has less resistance to both water and air. Fiberglass floats are also tougher than foam floats.
On the other hand, foam floats are lighter and less expensive. You most often see foam floats on smaller planes for these reasons.
Now, it is up to you to decide which one is "best" for your application.
