Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
receiver crystals
Old 06-29-2004 | 09:27 PM
Default receiver crystals
Is there any way to tell if a crystal is Futaba or Hitec? Also can you tell if the crystal is single or dual conversion? Some of my spare crystals have a red tag and some have a blue tag. The red tag says "dual conversion". Nothing on the blue tags. Thank you, in advance, for any assistance.
waiting . . . . . . . . . . . .
Old 06-29-2004 | 09:38 PM
scott88-RCU's Avatar
Default RE: receiver crystals
I've got a GWS crystal that says 28 and it's got a red tag, it's also for the Futaba shift. Hope this helps.
Old 06-30-2004 | 07:05 AM
Matt Kirsch's Avatar
My Feedback: (21)
You can't really go by the color of the tag. None of my GWS crystals have tags on them at all, and I seem to remember GREEN tags on my Hitec crystals.
If I remember correctly, my Futaba receiver crystals do have red tags, but they also have "Futaba" written on the tag.
Figuring them out, if you can, is going to be tough.
Old 06-30-2004 | 03:12 PM
along these lines, can someone help me??!! i have an electrifly receiver for the slinger (as recommended by Tower) and i got an electrifly crystal the same frequency as my futaba radio..for some reason the receiver and radio don't "jive"..do i need a special type of receiver crystal?? thank you
Old 07-01-2004 | 07:36 AM
My Feedback: (21)
I don't see where an electrifly receiver is recommended by Tower, but that doesn't matter. The standard receiver that came with the radio should work just fine.
What brand of transmitter do you have? Electrifly receivers are not compatible with JR or Airtronics, or any AM transmitters.
As long as you have the crystal that is recommended for the receiver, on the correct channel, it should work. I would contact Great Planes product support at [email protected] for advice. You probably have a faulty receiver or crystal.
Old 07-01-2004 | 09:09 AM
thank you for the info..i will get in touch with them. actually, the receiver was just the one that was listed in the "required additional items". hopefully i can get this thing to work! thanks again!
