Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 omei 2000 ep basic questions >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 10-05-2004 | 04:53 PM
Default omei 2000 ep basic questions
will the omei fly ok with the speed 580 motor that comes with it?or should i buy a better motor,or a different prop? to get ok performance,just recreational flying?
also where do i buy foam core wings that have been veneered...online?
thanks for any response.............
Old 10-06-2004 | 06:45 AM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: omei 2000 ep basic questions
You're going to have to provide more information about the plane. I've never heard of it, that's for sure.
We need weight, wingspan, wing area, length, type of plane, battery info, gearbox, prop, motor... That kind of stuff.
Old 10-06-2004 | 09:56 AM
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
i read a thread about a guy who built it and it hardly climbed with the stock components?
wadda you think?
better motor?
different prop?
thanks
Old 10-06-2004 | 10:00 AM
Wingspan 75 inches
Length 45.5 inches
All built Fiberglass Fuse
Engine size: 540 Class (Included)
Weight 2.9-3.1 lbs
Wing Area is 449.5 in²
RG-15 Modify
Radio: 3-Ch Transmitter, 3 servos
computers!
Old 10-24-2004 | 11:54 PM
Just ordered one after crashing my spirit select. Plan to start out with all omei stock and reuse the spirit radio and servos. The specs indicate standard servos can be used fut-S3003. Does anybody know if the Spirit select 8.4v 2100mAh battery can be used in this bird ?. I'm concerned about the weight. Thx in advance.
Old 04-06-2005 | 08:43 PM
My Feedback: (8)
is the omei 2000 set up for one servo in each wing for the ailerons or is it just one servo for both wings?
i wanted to set up flaps/ spoilers which makes it necessary for the ailerons to be powered
by 2 servos (one for each side).
thanx.
Old 04-06-2005 | 11:59 PM
yep, there are two servos for the ailerons. Channel 1+5 for flaperons would work great and is definately needed IMO.
