Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
prop question
Old 01-07-2005 | 10:18 AM
suitcase's Avatar
Default prop question
I'd like to know what the difference is between slo fly and e props. Other than the obvious, looks. My son in law has a NES Mamba and the prop shaft is barely long enough to get the nut on with a E prop. I compared the 9X4.5E to the sol fly 9X4.7 and the slo fly seemed too flimsy for the Mamba. Whatcha think??
Old 01-07-2005 | 05:33 PM
BadSplice's Avatar
Default RE: prop question
perhaps you could get a prop adaptor to go on the shaft? is it a direct drive motor or a geared one?
Old 01-07-2005 | 11:39 PM
Matt Kirsch's Avatar
My Feedback: (21)
You've already observed the difference: Looks, and weight. The Slo-Fly prop is meant for slow-flyers, anything that would use a GWS prop. Thin Electric props are meant for higher power applications.
As BadSplice alludes, you can get a longer prop adapter.
Old 01-08-2005 | 12:34 AM
Hatty's Avatar
What Matt said along with this:
If you didn't figure it out, slo-fly props are designed to be spun at low rpms. They push a large volume of air at a slow velocity. This, in turn, makes the plane fly slower. They are more efficient at creating thrust, which is why they are used.
E props, on the other hand, spin fast pushing a low volume of air. The plane will fly faster because of this. They are used a lot with direct drive configurations.
Old 01-08-2005 | 12:37 AM
Hatty's Avatar
I forgot to mention that the choice of a prop depends on your motor and whether or not it is geared. It is best to do what the manufacturer of your powerplant recommends.
